KB-26869: Alarm filter in an SQL query.
Question:
In the application, I have the following folder structure for alarms:
alarms\general\se01\switch01
                   \switch02
                   \switch20
How can I set up the return all alarms from all switches of a certain substation in an SQL query?
Solution:
To do so, you must use the “%” character. For example, if you want to know the alarms from substation “se01“, use:
alarms\general\se01\%
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
