KB-26858: Converting date/time variable into Double. 25 de março de 2019Elipse SoftwareDeixe um comentário on KB-26858: Converting date/time variable into Double. Question: How can I convert a date/time variable into Double? Solution: To do so, you must use the VBScript’s CDbl() function. Este artigo foi útil? Was this helpful? Submit Rating Classificação média - Average rating 0 / 5. Count: 0
