KB-24049: Importing a screen from another Elipse SCADA application.
Question:
Can a screen from another Elipse SCADA application be imported?
Solution:
Yes. To do so, in the new application, click Import… button on the Organizer’s Application item, and select the application that contains the screen to be imported.
A window opens with the source application at the right side and the new screen at the left side. To import an item from the source application to the new one, just click on it at the right side and drag it to the new application.
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
