Question:
How can I establish communication between Elipse’s supervisory systems (Elipse SCADA or E3) and the device via Profibus DP protocol?
Solution:
To establish communication with a Profibus network, it is recommended that you use Applicom’s interface controllers. The manufacturer also supplies an OPC Server. Therefore, the supervisory will communicate with the controller via OPC, which will in turn communicate with the Profibus network.
