KB-19299: Comparing dates in a script.
Question:
How can two dates from two different sources be compared to each other?
Solution:
To do so, you must use CDate() command to format the dates before they are compared.
Sample script to be executed at a button’s Click event:
Set Data1 = Application.GetObject(“Data.DataTag1″).Value
Set Data2 = Application.GetObject(“Data.DataTag2″).Value
If CDate(Data1) = CDate(Data2) Then
    MsgBox “Same”
Else
    MsgBox “Different”
End If
Print Friendly, PDF & Email
Deixe seu Comentário
