KB-18907: Checking WriteRecord() command’s execution.
Question:
How can I check if the WriteRecord() command was successfully executed?
Solution:
To do so, you must pass the command’s return to an auxiliary variable, and execute an IF command to check the result. For example:
dim aux
aux = Hist1.WriteRecord()
If aux == 1     // writing ok
  MessageBox(“ok”)
ElseIf aux == 0     // writing is not ok
  MessageBox(“it is not ok”)
endIf
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
