Generating a random number.
Question:
Is it possible to set the application to generate a random number?
Solution:
Yes, it is.
To do so, use the following script:
MaxValue = 10
MinValue = 50
Range = MaxValue – MinValue
‘Starts the random numbers generator
Randomize
‘Applies the formula
RandomValue = Round((Range * Rnd) + MinValue)
Randomize function generates a random number between 0 (which can be generated) and 1 (which cannot be generated).  We use the formula to set the necessary values interval, according to what you need in the application.
NOTE: Attached to this article is a sample application developed with E3 V3.2 B255.
ProjRandom en
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
