Description:
The DriverLib library is a feature that allows setting up the driver, creating tags, testing communication, and visualizing log events, all at runtime.
How to use this library:
- Extract the attached file into the application file.
- Add the library to its domain.
- Add an XcConfigDriver object to a screen.
- Link the object to the desired driver, at Source property.
- Run the application.
NOTE: The attached application was developed with Elipse E3 version 3.5 build 338.
