BUG-0009969: TagTimer not executing OnPreset event if TriggerType property is set as ttDaily
OVERVIEW
When TagTimer’s TriggerType property is set as a daily trigger (ttDaily), OnPreset event will be called just once.
HOW CAN I REPRODUCE THIS PROBLEM?
Create a TagTimer in the application and set its TriggerType property as ttDaily.
WORKAROUND
It is possible to set a daily trigger by setting TriggerType property as ttContinuous and RepeatInterval property as 23:59:59.
SITUATION
Elipse Software has confirmed that this is in fact a bug from the products listed by the end of this article. The correction download can be found here.
THIS ARTICLE APPLIES TO THESE PRODUCTS
Elipse E3 version 3.0 build 122 or higher
Elipse E3 version 3.1
Print Friendly, PDF & Email
Deixe seu Comentário
Floating button icon
Pesquise com IA
