Elipse Knowledgebase
Communicating with Siemens' LOGO PLC.
Question:
Is there any Elipse I/O driver that can communicate with Siemens' LOGO PLC?
Solution:
No; Siemens' LOGO PLCs use a proprietary (closed/restricted) protocol, of which Elipse has no implemented driver. However, LOGO!8 has a native Ethernet interface, which enables communication with M-Prot driver.
Depending on the PLC's version, you can use OPC communication. We suggest you get in touch directly with the device's technical support to check whether the model being used is compatible with OPC protocol.
Artigos Relacionados
Anexos
Comentários de Usuários
Comentários do artigo 'Communicating with Siemens' LOGO PLC.'
   Nome:
   E-mail:
* Comentário:
* Digite o código abaixo:
Detalhes do Artigo
Última Atualização
11th of October, 2017
Autor
Délio Damin
Você gostaria de...
 Avise-me
Editar este Artigo
Edição Rápida
Opinião dos Usuários
Nenhum usuário votou ainda.
Obrigado pelo seu voto.
Continuar
