Elipse Knowledgebase
KB-42306: Running ExecuteExternalApp method in a server’s script.
Question:
How can I run the ExecuteExternalApp method in a server's script?
Solution:
To do so, you can use the script below, which will perform the same task:
Set shell = CreateObject("WScript.Shell")
shell.Run "C:\arquivo.txt"
Set shell = Nothing
NOTE: There are certain restrictions to using Shell object in Win XP, since in Windows Vista and higher versions the services running in the SYSTEM account (such as E3Run) can no longer show windows; that is, they can no longer "interact with the desktop". In this case, the alternative is to add the scripts running programs with windows only in Viewer events, via ExecuteExternalApp method, or via Run Application pick. To do so, the folder holding the file must be shared on the network in order to be accessed from different client viewers/machines.
Artigos Relacionados
Anexos
Comentários de Usuários
Comentários do artigo 'KB-42306: Running ExecuteExternalApp method in a server’s script.'
   Nome:
   E-mail:
* Comentário:
* Digite o código abaixo:
Detalhes do Artigo
Última Atualização
4th of May, 2017
Autor
Mateus Machado
Você gostaria de...
 Avise-me
Editar este Artigo
Edição Rápida
Opinião dos Usuários
Nenhum usuário votou ainda.
Obrigado pelo seu voto.
Continuar
