KB-30665: Working with functions in E3 scripts.
Question:
How can I work with a function in E3 scripts?
Solution:
To do so, you must set the function with the structure:
Function Name(parameter1, parameter2,.., parameterN)
 script
End function
Example:
Sub CommandButton1_Click()
 ‘Sums the values by using the Sum function
 result = Sum(10, 20)
 MsgBox result
‘Function’s declaration
Function Sum(a, b)
   Sum =  a + b
End Function
‘Sub Empty just to keep the structure
Sub Empty_Sub()
