Elipse Knowledgebase
KB-35928: Save() method at OnStopRunning event not working.
Question:
At an application, Save() method is used on the DataFolder object's OnStopRunning event to save a SetPoint's content. However, when the computer unexpectedly shuts down, the SetPoint's content is lost. Why does this occur?
Solution:
This occurs because the OnStopRunning event is being used on the DataFolder object, which belongs to the server; so, to be executed, this event expects that you close the E3 Server first.
Thus, to make it properly work on this event, you must close the E3 Server (via E3Admin--Domain--Close option) before turning off the computer.
However, we recommend that you use Save() method on another event, in order to prevent the event from not being executed if the computer unexpectedly shuts down.
Artigos Relacionados
Anexos
Comentários de Usuários
Comentários do artigo 'KB-35928: Save() method at OnStopRunning event not working.'
   Nome:
   E-mail:
* Comentário:
* Digite o código abaixo:
Detalhes do Artigo
Última Atualização
20th of July, 2017
Autor
Marco Antonio Gomes Silva
Você gostaria de...
 Avise-me
Editar este Artigo
Edição Rápida
Opinião dos Usuários
Nenhum usuário votou ainda.
Obrigado pelo seu voto.
Continuar
