Although most of VBscript's aspects apply to scripts programming at E3, some features about implementing the concept of object-oriented system must be highlighted.
In this tutorial, the objective is to acquaint you with the use of VBScript in the E3 through examples and exercises. Each chapter contains exercises and an application with the answers attached. For better understanding of the exercises, it will be necessary to consult E3's Script Manual, available with the software installation and for download at the site.
