Elipse Knowledgebase
KB-32158: Logging into the WebViewer.
Question:
How can I ensure the WebViewer will require a login and password when it opens?
Solution:
The WebViewer works the same way as the Viewer, which means the login and password will be required with a script in Viewer's OnStartRunning event calling Viewer's Login method.
If you follow these steps and the login is cancelled, the application's initial screen will open.
If you wan the Viewer/WebViewer to run only after the password has been validated, you must set up a user in the application to not be allowed to open the screen:
By doing this, you will no longer need the script suggested above, and if the login in cancelled, the initial screen will not be opened.
Artigos Relacionados
Anexos
Comentários de Usuários
Comentários do artigo 'KB-32158: Logging into the WebViewer.'
   Nome:
   E-mail:
* Comentário:
* Digite o código abaixo:
Detalhes do Artigo
Última Atualização
1st of August, 2014
Autor
Mussara, Bruno
Você gostaria de...
 Avise-me
Editar este Artigo
Edição Rápida
Opinião dos Usuários
Nenhum usuário votou ainda.
Obrigado pelo seu voto.
Continuar
