Elipse Knowledgebase
KB-23095: Element count in a block tag.
Question:
I've added a 10-element I/O block to a driver folder, and even after one of the elements had been deleted, the option Tag counting still indicates the same 10 elements as before. How does the element count in a block tag works?
Solution:
The total amount of elements in a block is indicated by its Size property. So, whenever you insert or delete elements from the block, you will have to change its Size property.
Artigos Relacionados
Anexos
Comentários de Usuários
Comentários do artigo 'KB-23095: Element count in a block tag.'
   Nome:
   E-mail:
* Comentário:
* Digite o código abaixo:
Detalhes do Artigo
Última Atualização
3rd of July, 2014
Autor
Pudi, Ricardo Meurer
Você gostaria de...
 Avise-me
Editar este Artigo
Edição Rápida
Opinião dos Usuários
Nenhum usuário votou ainda.
Obrigado pelo seu voto.
Continuar
