Elipse Knowledgebase
Basic VBScript for Elipse E3: Lesson 7 - GetADORecordSet
Query's GetADORecordSet method returns an  ADO (ActiveX Data Object) type Recordset, resulting from the execution of the configured query.
The ADO Recordset object is used to access a chart's record in the database. It has the following properties and methods:
Properties:
BOF: Returns true if the position of the pointer is previous to the first record.
EOF: Returns true if the position of the pointer is posterior to the last record.
RecordCount: Returns the number of records in the chart.
Methods:
MoveFirst: Moves the pointer to the first record.
MoveLast: Moves the pointer to the last record.
MoveNext: Moves the pointer to the next record.
MovePrevious: Moves the pointer to the previous record.
To access the records individually, we use Fields ("FieldName") command.
Example:
set RS = Screen.Item("Query1").GetADORecordset()
for i=1 to RS.RecordCount
    Field1 = RS.Fields("Field1").Value
    Field2 = RS.Fields("Field2").Value
    Field3 = RS.Fields("Field3").Value
    MsgBox Field1 &vbTab& Field2 &vbTab& Field3
next
Exercises:
1. Insert a Database object in the project and configure it.
2. Create 3 demonstration tags and record them in the Database using the Historic object. In the Historic, set recording time to 0 seconds.
3. Insert a button on screen that when clicking records a register in the Historic. (WriteRecord)
4. Insert a query object on screen that searches the data saved by the Historic.
5. Create a button on screen that when clicking, displays every row in the Historic. Use the While command to repeat the script until it has not reached the end of the chart.
Related Articles
Visitor Comments
Post Comment for "Basic VBScript for Elipse E3: Lesson 7 - GetADORecordSet"
   Name:
   Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
28th of October, 2009
Autor
Paula Pereira Enéas
Would you like to...
 Subscribe me
Edit this Article
Quick Edit
Export to PDF
User Opinions
No users have voted.
Continue
