Elipse Knowledgebase
KB-15050: Activating Windows Script Debugger
Question:
How can I activate Windows Script Debugger?
Solution:
Scripts can be debugged in E3 both in the server and in the Viewer. To do so, you must install the Microsoft Script Debugger and enable “Just-in-time Debugger” by setting 1 as the value of two keys on the REGEDIT:
- HKEY_CURRENT_USER\Software\Microsoft\Windows Script\Settings\JITDebug;
- From E3 version 3.0 on, set the key HKEY_USERS\S-1-5-18\Software\Microsoft\Windows Script\Settings\JITDebug.
The debugger is activated in two different situations:
1) When there are runtime errors (which will appear only in E3 logs); or
2) When setting STOP command in a script (it forces a breakpoint when the script is executed).
In either situation, a window will pop up asking whether you wish to open the debugger (from a list of available debuggers); select one, and click on Yes.
It is also possible to open the debugger manually (in Internet Explorer, go to Tools—Internet Options—Advanced (and then clean Browsing option)—Disable Script Debugging. Leave IE, then return to it, and access View—Script Debugger—Open. Finally, click on “Attach Process” to Viewer or E3Run.
Check the links below to download the Script Debugger:
For Windows 98 and Me -> Click here.
For Windows NT, 2000, 2003 and XP -> Click here.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
Post Comment for "KB-15050: Activating Windows Script Debugger"
   Name:
   Email:
* Comment:
* Enter the code below:
Article Details
Last Updated
23rd of July, 2010
Autor
Pudi, Ricardo Meurer
Would you like to...
 Subscribe me
Edit this Article
Quick Edit
Export to PDF
User Opinions
No users have voted.
Continue
